Hello everyone,
I’m experiencing a critical issue with PiKVM v4 Plus where WebRTC video streams fail on restrictive networks (mobile hotspots, certain international ISPs) despite correct TURN server configuration.
Setup:
PiKVM v4 Plus running kvmd-platform-v4plus-hdmi-rpi4 4.61-1
Accessing via Tailscale VPN for security
Two-way audio successfully configured and working on standard networks
Target: I need access when im in a different country through restrictive ISP
Problem:
WebRTC connection establishes initially (video works for 5-6 seconds)
Video stream dies with “Remote track muted” in console logs
Pattern: Connect → Video starts → Dies in 5-6 seconds → Falls back to MJPEG (also fails)
Mouse/keyboard control continues working (control channel OK, video channel fails)
Issue ONLY occurs on restrictive networks (works perfectly on standard home/office networks)
Critical Requirements:
WebRTC must work (need 2-way audio functionality)
Must work through restrictive networks that block UDP/P2P
Must maintain security (no IP leaks to target machine)
What I’ve Tested:
TURN Configuration in override.yaml:
Configured Metered.ca TURN servers with proper credentials
Added both UDP and TCP transport options
TURN servers are contacted (verified 28KB usage on dashboard)
However, TURN is only used for signaling, NOT for media relay
Custom Janus Static Configuration:
Switched to kvmd-janus-static
Added TURN configuration to /etc/kvmd/janus/janus.jcfg
Result: Broke WebRTC entirely, had to revert
Network Diagnostics:
Ping through VPN: ~50-60ms latency, 3% packet loss (acceptable)
chrome://webrtc-internals shows connection never progresses past “new” state
Verified TURN credentials are valid and servers reachable
Root Cause Analysis: Based on extensive testing, PiKVM v4 Plus’s Janus WebRTC implementation appears to:
Use TURN for initial signaling/connection setup only
NOT relay actual video stream through TURN servers
Attempt direct peer-to-peer for video even when it should use relay
This fails through VPN + restrictive networks combination
Question: Is there a way to force PiKVM v4 Plus to use TURN servers for actual media relay, not just signaling? The current implementation seems to ignore the need for relay even when direct connection is impossible.
I’ve documented this extensively and can provide logs, config files, or additional testing if needed. This is blocking our ability to provide remote support to international contractors on restrictive networks.
Thank you for your attention to this issue. PiKVM is an excellent product, and solving this TURN relay issue would make it perfect for our use case.
Best regards, A complete freaking beginner at this who’s using claude ai to help me set this up.
Additional Context: This is a well-documented WebRTC requirement - when both peers are behind symmetric NATs or restrictive firewalls, TURN relay is mandatory for establishing connections (not just for signaling, but for actual media relay). STUN alone cannot facilitate connections in these scenarios. Reference: Common WebRTC deployment patterns confirm TURN is required for ~15-20% of connections globally, particularly for users in countries with restrictive ISPs or on mobile networks.
