I just set up my PiKVM V4 Plus. I can see the audio slider which works fine , but the microphone is not showing up. I’ve updated the device and tried several troubleshooting steps, but nothing seems to work.
Hi Mraf,
Did you follow the steps under docs.pikvm.org/usb_audio to enable it in the override file after doing an update to the latest with pikvm-update? If you haven’t reflashed the microSD that is the quickest way to get it enabled, as I believe it is turned on by default in the newer images.
I have not tried that i will try it and let you know . thanks for your response .
Hi @Mraf ,
Any luck with the enabling of the audio using the override.yaml?
