I2c for OLED
I did some research but couldn’t find an answer. I apologize if this has already been answered. I added an i2c OLED to my DIY PiKVM and enabled it. So far, no problems. However, I need to rotate the screen 180 degrees, and I haven’t figured out how. Thanks in advance for your help.
Hi Ferdi, welcome to our forum.
From the FAQ:
  1. mkdir -p /etc/systemd/system/kvmd-oled.service.d
  2. create /etc/systemd/system/kvmd-oled.service.d/override.conf:
[Service]
ExecStart=
ExecStart=/usr/bin/kvmd-oled --clear-on-exit --rotate=0
from kvmd-oled --help:
  --rotate, -r ROTATION
                        Rotation factor. Allowed values are: 0, 1, 2, 3 (default: 2)
  1. restart kvmd-oled or reboot the device
Hope this helps.
Cheers,
Nick
Hello Nick,
Thanks for help but I did everything you said. Unfortunately, nothing changes. I also tried all the options (0-1-2-3).
Depending on the screen device, you might need to specify other command line parameters, many of which are specific to particular hardware. Sometimes explicitly specifying screen height helps, which is rather counterintuitive.
@ewspikvm: any other ideas?
Are you using the DIY v1 or v2 image?
Hello, I’m using V2 image with Pi4 and 0.91’’ 128X32 SSD1306
Thanks & Regards;
After you created the service file with the changed parameters, did you also enable and restart the service, or restart the PiKVM?
I first tried stopping the service. When that didn’t work, I tried restarting the system completely after each change, but the results remained the same.
Thanks,
If you run kvmd -m through a shell, does it show any configuration sections for the OLED there?
Ferdi,
Could you please edit your post or post it again, and make sure the whole output is formatted correctly? Our forum software interprets what you type/paste as markdown text, hence the resulting mess.
Reference: Discourse Guide: Code Formatting - Meta - Stonehearth Discourse
Thank you.
[root@kvm-pve01 ~]# kvmd -m
ipmi:
    auth:
        file: /etc/kvmd/ipmipasswd
    kvmd:
        timeout: 5.0
        unix: /run/kvmd/kvmd.sock
    server:
        host: ''
        port: 623
        timeout: 10.0
    sol:
        device: ''
        proxy_port: 0
        select_timeout: 0.1
        speed: 115200
janus:
    check:
        interval: 10.0
        retries: 5
        retries_delay: 5.0
    cmd:
        - /usr/bin/janus
        - --disable-colors
        - --plugins-folder=/usr/lib/ustreamer/janus
        - --configs-folder=/etc/kvmd/janus
        - --interface={src_ip}
        - '{o_stun_server}'
    cmd_append: []
    cmd_remove: []
    stun:
        host: stun.l.google.com
        port: 19302
        retries: 5
        retries_delay: 5.0
        timeout: 5.0
kvmd:
    atx:
        click_delay: 0.1
        device: /dev/gpiochip0
        hdd_led_debounce: 0.1
        hdd_led_inverted: false
        hdd_led_pin: 22
        long_click_delay: 5.5
        power_led_debounce: 0.1
        power_led_inverted: false
        power_led_pin: 24
        power_switch_pin: 23
        reset_switch_pin: 27
        # type: ''
        type: gpio
    auth:
        enabled: true
        expire: 0
        external:
            type: ''
        internal:
            file: /etc/kvmd/htpasswd
            force_users: []
            type: htpasswd
        totp:
            secret:
                file: /etc/kvmd/totp.secret
        usc:
            groups:
                - kvmd-selfauth
            users: []
    gpio:
        drivers:
            __gpio__:
                type: gpio
        scheme:
        state_poll: 0.1
        view:
            header:
                title: GPIO
            table: []
    hid:
        ignore_keys: []
        jiggler:
            active: false
            enabled: true
            interval: 60
        keyboard:
            device: /dev/kvmd-hid-keyboard
            queue_timeout: 0.1
            select_timeout: 0.1
            write_retries: 150
        keymap: /usr/share/kvmd/keymaps/en-us
        mouse:
            absolute: true
            absolute_win98_fix: false
            device: /dev/kvmd-hid-mouse
            horizontal_wheel: true
            queue_timeout: 0.1
            select_timeout: 0.1
            write_retries: 150
        mouse_alt:
            device: /dev/kvmd-hid-mouse-alt
            queue_timeout: 0.1
            select_timeout: 0.1
            write_retries: 150
        mouse_x_range:
            max: 32767
            min: -32768
        mouse_y_range:
            max: 32767
            min: -32768
        noop: false
        # type: ''
        type: otg
    info:
        extras: /usr/share/kvmd/extras
        fan:
            daemon: kvmd-fan
            state_poll: 5.0
            timeout: 5.0
            unix: ''
        hw:
            ignore_past: false
            platform: /usr/share/kvmd/platform
            state_poll: 5.0
            vcgencmd_cmd:
                - /usr/bin/vcgencmd
        meta: /etc/kvmd/meta.yaml
    log_reader:
        enabled: true
    msd:
        initial:
            cdrom: false
            image: ''
        read_chunk_size: 65536
        remount_cmd:
            - /usr/bin/sudo
            - --non-interactive
            - /usr/bin/kvmd-helper-otgmsd-remount
            - '{mode}'
        sync_chunk_size: 4194304
        # type: ''
        type: otg
        write_chunk_size: 65536
    ocr:
        langs:
            - eng
        tessdata: /usr/share/tessdata
    prometheus:
        auth:
            enabled: true
    server:
        access_log_format: '[%P / %{X-Real-IP}i] ''%r'' => %s; size=%b --- referer=''%{Referer}i''; user_agent=''%{User-Agent}i'''
        heartbeat: 15.0
        unix_mode: 432
        unix_rm: true
    snapshot:
        idle_interval: 0.0
        live_interval: 0.0
        online_delay: 5.0
        retries: 10
        retries_delay: 3.0
        wakeup_key: ''
        wakeup_move: 0
    streamer:
        # cmd:
        #     - /bin/true
        cmd:
            - /usr/bin/ustreamer
            - --device=/dev/kvmd-video
            - --persistent
            - --dv-timings
            - --format=uyvy
            - --buffers=6
            - --encoder=m2m-image
            - --workers=3
            - --quality={quality}
            - --desired-fps={desired_fps}
            - --drop-same-frames=30
            - --unix={unix}
            - --unix-rm
            - --unix-mode=0660
            - --exit-on-parent-death
            - --process-name-prefix={process_name_prefix}
            - --notify-parent
            - --no-log-colors
            - --jpeg-sink=kvmd::ustreamer::jpeg
            - --jpeg-sink-mode=0660
            - --h264-sink=kvmd::ustreamer::h264
            - --h264-sink-mode=0660
            - --h264-bitrate={h264_bitrate}
            - --h264-gop={h264_gop}
        cmd_append: []
        cmd_remove: []
        desired_fps:
            default: 40
            max: 70
            min: 0
        forever: false
        h264_bitrate:
            # default: 0
            default: 5000
            max: 20000
            min: 25
        h264_gop:
            default: 30
            max: 60
            min: 0
        post_stop_cmd:
            - /bin/true
            - post-stop
        post_stop_cmd_append: []
        post_stop_cmd_remove: []
        pre_start_cmd:
            - /bin/true
            - pre-start
        pre_start_cmd_append: []
        pre_start_cmd_remove: []
        process_name_prefix: kvmd/streamer
        quality: 80
        reset_delay: 1.0
        resolution:
            available: []
            default: ''
        shutdown_delay: 10.0
        snapshot_timeout: 5.0
        state_poll: 1.0
        timeout: 2.0
        unix: /run/kvmd/ustreamer.sock
    switch:
        default_edid: /etc/kvmd/switch-edid.hex
        device: /dev/kvmd-switch
        ignore_hpd_on_top: false
localhid:
    kvmd:
        timeout: 5.0
# logging: {}
logging:
    disable_existing_loggers: false
    formatters:
        console:
            (): logging.Formatter
            format: '{name:30.30} {levelname:>7} --- {message}'
            style: '{'
    handlers:
        console:
            class: logging.StreamHandler
            formatter: console
            level: DEBUG
            stream: ext://sys.stderr
    root:
        handlers:
        - console
        level: INFO
    version: 1
media:
    memsink:
        h264:
            drop_same_frames: 0.0
            lock_timeout: 1.0
            # sink: ''
            sink: kvmd::ustreamer::h264
            wait_timeout: 1.0
        jpeg:
            lock_timeout: 1.0
            sink: ''
            wait_timeout: 1.0
    server:
        heartbeat: 15.0
        unix: /run/kvmd/media.sock
        unix_mode: 432
        unix_rm: true
nginx:
    http:
        ipv4: 0.0.0.0
        ipv6: '::'
        port: 80
    https:
        enabled: true
        ipv4: 0.0.0.0
        ipv6: '::'
        port: 443
otg:
    config: ''
    device_version: -1
    devices:
        audio:
            enabled: false
            start: true
        drives:
            count: 1
            default:
                cdrom: false
                fua: true
                inquiry_string:
                    cdrom:
                        product: Optical Drive
                        revision: '1.00'
                        vendor: PiKVM
                    flash:
                        product: Flash Drive
                        revision: '1.00'
                        vendor: PiKVM
                removable: true
                rw: true
                stall: false
            enabled: false
            start: true
        ethernet:
            driver: ecm
            enabled: false
            host_mac: ''
            kvm_mac: ''
            start: true
        hid:
            keyboard:
                start: true
            mouse:
                start: true
            mouse_alt:
                start: true
        msd:
            default:
                cdrom: true
                fua: true
                inquiry_string:
                    cdrom:
                        revision: '1.00'
                        vendor: PiKVM
                    flash:
                        revision: '1.00'
                        vendor: PiKVM
                removable: true
                rw: false
                stall: false
            start: true
        serial:
            enabled: false
            start: true
    endpoints: 9
    gadget: kvmd
    init_delay: 3.0
    manufacturer: PiKVM
    max_power: 250
    meta: /run/kvmd/otg
    product: PiKVM Composite Device
    product_id: 260
    remote_wakeup: true
    serial: CAFEBABE
    udc: ''
    usb_version: 512
    user: kvmd
    vendor_id: 7531
otgnet:
    commands:
        ip_cmd:
            - /usr/bin/ip
        iptables_cmd:
            - /usr/sbin/iptables
            - --wait=5
        post_start_cmd:
            - /usr/bin/systemd-run
            - --unit=kvmd-otgnet-dnsmasq
            - /usr/sbin/dnsmasq
            - --conf-file=/dev/null
            - --pid-file
            - --user=dnsmasq
            - --interface={iface}
            - --port=0
            - --dhcp-range={dhcp_ip_begin},{dhcp_ip_end},24h
            - --dhcp-leasefile=/run/kvmd/dnsmasq.lease
            - --dhcp-option={dhcp_option_3}
            - --dhcp-option=6
            - --keep-in-foreground
        post_start_cmd_append: []
        post_start_cmd_remove: []
        post_stop_cmd:
            - /bin/true
            - post-stop
        pre_start_cmd:
            - /bin/true
            - pre-start
        pre_stop_cmd:
            - /usr/bin/systemctl
            - stop
            - kvmd-otgnet-dnsmasq
        pre_stop_cmd_append: []
        pre_stop_cmd_remove: []
        sysctl_cmd:
            - /usr/sbin/sysctl
    firewall:
        allow_icmp: true
        allow_tcp: []
        allow_udp:
            - 67
        forward_iface: ''
    iface:
        net: 172.30.30.0/24
pst:
    remount_cmd:
        - /usr/bin/sudo
        - --non-interactive
        - /usr/bin/kvmd-helper-pst-remount
        - '{mode}'
    ro_cleanup_delay: 3.0
    ro_retries_delay: 10.0
    server:
        heartbeat: 15.0
        unix: /run/kvmd/pst.sock
        unix_mode: 432
        unix_rm: true
vnc:
    auth:
        vencrypt:
            enabled: true
        vncauth:
            enabled: false
            file: /etc/kvmd/vncpasswd
    desired_fps: 30
    kvmd:
        timeout: 5.0
    memsink:
        h264:
            lock_timeout: 1.0
            # sink: ''
            wait_timeout: 1.0
        jpeg:
            drop_same_frames: 1.0
            lock_timeout: 1.0
            # sink: ''
            sink: kvmd::ustreamer::jpeg
            wait_timeout: 1.0
    mouse_output: usb
    scroll_rate: 4
    server:
        host: ''
        keepalive:
            count: 3
            enabled: true
            idle: 10
            interval: 3
        max_clients: 10
        no_delay: true
        port: 5900
        tls:
            ciphers: ALL:@SECLEVEL=0
            timeout: 30.0
            x509:
                cert: /etc/kvmd/vnc/ssl/server.crt
                key: /etc/kvmd/vnc/ssl/server.key
    streamer:
        timeout: 5.0
watchdog:
    interval: 30
    rtc: 0
    timeout: 300
[root@kvm-pve01 ~]#
@Nick and @ewspikvm thanks for helps and . I solved with delete configuration and re-create everything.
Thanks again for helps and your patience
Regards;
