Hi,
Has anybody managed to get a USB Capture card to work with the PiKVM V4 Plus?
My rationale here might be misguided, but I wanted to try to use an INOGENI 4K2USB3 capture card.
Ideally, I wanted to try either 1080p or 1440p with it, and see if I could get the latency as low as possible.
I’m far from an expert in video encoding/transcoding so I’m going on basic research here, but from what I can see, the 4K2USB says that it supports YUY2 4:2:2 and NV12/I420/YV12 4:2:0 for USB 3.0, which should mean that the PiKVM CPU wouldn’t be taxed much, and it should be able to stream it
It also UVC compliant, so I think it should work.
When I run
v4l2-ctl --list-devices
I get:
bcm2835-codec-decode (platform:bcm2835-codec):
/dev/video10
/dev/video11
/dev/video12
/dev/video18
/dev/video31
/dev/media3bcm2835-isp (platform:bcm2835-isp):
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video20
/dev/video21
/dev/video22
/dev/video23
/dev/media2
/dev/media4unicam (platform:fe801000.csi):
/dev/video0
/dev/media1rpivid (platform:rpivid):
/dev/video19
/dev/media0041D-INOGENI 4K2USB3 (usb-0000:01:00.0-1):
/dev/video1
/dev/video2
/dev/media5
Running v4l2-ctl --list-formats-ext -d /dev/video1 gives me:
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture[0]: 'YUYV' (YUYV 4:2:2) Size: Discrete 1280x720 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1080 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1200 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x576 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 640x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 800x600 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1024x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x1024 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x960 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x800 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1360x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1680x1050 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) [1]: 'YV12' (Planar YVU 4:2:0) Size: Discrete 1280x720 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1080 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1200 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x576 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 640x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 800x600 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1024x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x1024 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x960 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x800 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1360x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 3840x2160 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 4096x2160 Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 2560x1440 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) [2]: 'NV12' (Y/UV 4:2:0) Size: Discrete 1280x720 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1080 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1200 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x576 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 640x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 800x600 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1024x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x1024 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x960 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x800 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1360x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 3840x2160 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 4096x2160 Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 2560x1440 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) [3]: 'YU12' (Planar YUV 4:2:0) Size: Discrete 1280x720 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1080 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1920x1200 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 720x576 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 640x480 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 800x600 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1024x768 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x1024 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 1280x960 Interval: Discrete 0.017s (60.000 fps) Interval: Discrete 0.017s (59.940 fps) Interval: Discrete 0.020s (50.000 fps) Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) ...... Size: Discrete 3840x2160 Interval: Discrete 0.033s (30.000 fps) Interval: Discrete 0.033s (29.970 fps) Interval: Discrete 0.040s (25.000 fps) Interval: Discrete 0.042s (24.000 fps) Interval: Discrete 0.042s (23.976 fps) Size: Discrete 2560x1440 Interval: Discrete 0.017s (60.000 fps) ...
But when I try to use an override, I don’t get any video.
I’ve tried a few different options, most recently
kvmd:
streamer:
quality: 0
resolution:
default: 1920x1080
available:
- 1920x1080
- 1600x1200
- 1360x768
- 1280x1024
- 1280x960
- 1280x720
- 1024x768
- 800x600
- 720x576
- 720x480
- 640x480
cmd:- “/usr/bin/ustreamer”
- " – device=/dev/video1"
- " – persistent"
- " – format=mjpeg"
- " – resolution={resolution}"
- " – desired-fps={desired_fps}"
- " – drop-same-frames=60"
- " – last-as-blank=0"
- " – unix={unix}"
- " – unix-rm"
- " – unix-mode=0660"
- " – exit-on-parent-death"
- " – process-name-prefix={process_name_prefix}"
- " – notify-parent"
- " – no-log-colors"
- " – sink=kvmd::ustreamer::jpeg"
- " – sink-mode=0660"
But I don’t get any signal on PiKVM.
I did try
ustreamer --device=/dev/video1 --host=0.0.0.0
and I can access the stream via URL, so I know the capture card works and can get video, but I can’t get it working with the PiKVM website.
Does anybody know how I can get it working, or have you managed to get anything similar working?
Thank you.
