PiKVM Switch: recovering the firmware (UF2 reflash)
If your PiKVM Switch stopped responding (for example after a firmware update, or the Switch menu disappeared from the PiKVM web UI) but it still has power, you can reflash its firmware from any PC.
Before you start: check that LED #17 (green, on the back, to the right of the BOOT label) is lit. If it isn’t, the Switch isn’t getting power and this procedure won’t help. Contact support instead (see below).
  1. Download firmware.uf2 to a PC.
  2. Connect the Switch’s uplink CTL port to the PC.
  3. Power on the Switch.
  4. Press and hold BOOT.
  5. Press and release RESET.
  6. A flash drive named RPI-RP2 appears (containing INDEX.HTM and INFO_UF2.TXT). Release BOOT.
  7. Copy firmware.uf2 onto that drive. The drive disappears right after the copy; that’s normal, and the file won’t be there if you enter boot mode again.
  8. Within about 30 seconds the Switch reboots itself and LED #15 should blink amber. Reconnect it to your PiKVM.
If it doesn’t work:
  • No RPI-RP2 drive appears: the Switch’s controller isn’t responding. That’s a hardware fault.
  • The copy works but LED #15 never blinks: also a hardware fault.
In either case, email support@pishop.us (US) or support@pishop.ca (Canada) with your Switch’s serial number (sticker on the bottom), your order number, and what you saw at each step.
Edit: updated the firmware link. The PiKVM project moved the file (the old switch/switch.uf2 link no longer works); it’s now firmware.uf2.
